Re: 1st time lower unit removal, what is this part and where does it go?
Okay so now I finally got the seals off, i think I was being too gentle with it. Problem is they both fell out at same time so not sure which way the middle one goes, I know which way the bottom one goes but the one that is inside the bore I am not so sure abbout. I may be clearer when I get the parts. I would like to clean the inside of of this(bore) because it is oily and gritty. Would simple green be a good thing to soak a nd clean this in or should I stay away from simple green?
Also on the water pump where the tube looking thing is, I want to know if there is supposed to be a seal on top of it or small oring, the top part was a little melted which you can see in photo. There was a seal on top of waterpump with the driveshaft going thorough it but in my diagram it looks like there is also supposed to be what is called a waterline seal #9 in diagram which i never saw(it could have melted).
Also, my diagram has confused me a little I cannot find #32 in the parts i have taken off so far, it says the part is a retaining ring and I guess why it confuses me is that it is at the top of diagram between #3 & #4 and I am not sure what it is supposed to look like. From taking the lower unt apart so far I am finding that I do not have the same number of parts as showed in diagram. Here is diagram for my lower. http://www.boats.net/parts/search/Merc2/Force/85 H.P. (1989)/856X9G/GEAR HOUSING/parts.html
