2.5l block had a crack!
chiefalen
Ok Bt. doctur gave me a block.
No way he could have known there was a crack under the water pump on the head bolt hole.
I took off the pump and timing gear cover. There it was.
Ok i'm back to square one.
Now i'm thinking a running 3.0. Can't seem to find a block.
I don't know, i just don't.
Getting cold here in Jersey strippers are gonna be running soon. Weakfish already being caught.
Freekin 3.7 motors all over.
What to do?
JustJason
Re: 2.5l block had a crack!
Man cheifalen you've got about the worst luck i've seen in months :(
wvwarlock
have you checked with JASPER ENGINES yet? they are online and have locations everywhere.
fishrdan
No luck on Ebay or Craigslist?
Isn't the 2.5L the same block as a 153CI GM engine used in late 60's ChevyII cars? I know the 3.0L is a odd ball and some of the 2.5L parts are different, but thought the 2.5L was an automotive block,,, I could be wrong :rolleyes: Then again, what are the chances of find an engine from a 60's vehicle in a junk yard...
Too bad you are not on the west coast, I have an 2001 3.0 shortblock sitting in the garage. Probably wouldn't work anyway since it's a 1 piece rear main seal engine.
chiefalen
I don't freekin believe it. I'm looking now.
chiefalen
Thanks Dan believe me i'm looking. I might just get the whole boat with a running 3.0 and out drive.
fishrdan
And then put the engine and outdrive into your boat,, or ditch your boat and fix up the new one? Either way I think you will like the extra 20HP of a 3.0
chiefalen
Yep want the extra 20hp. Don't want to spend money i don't have.
Just wondering is a 85 merc the same transom hole as a 85 omc.
I don't think so.
