Model J60PLSSE
I'm not getting a spark on any of the cylinders on this motor.
We were running fine with it today, from idle to WOT. After running at idle for some length of time, the motor just quit. We tried restarting and it would run for a couple seconds then bog down and die. We tried pumping the bulb thinking it was a fuel issue (fuel pump). The motor ran strong for about 5 minutes then died, we were running at half throttle then trying to get back to the landing. This time it wouldn't start or even fire. Battery is in good shape, plenty of power to the starter, it cranks strong for however long we need, just no firing.
When I got home, I tried to start it again, still no firing. I pulled all the plugs, they were moist but otherwise looked fine (they are a couple years old, no wear or carbon, very clean). I tried to ground each to the cylinder head, no spark on any. I checked the connections of most of the wires to make sure nothing was loose, I checked the 20 amp fuse, all were fine. Not sure what else to check, any ideas?
thanks.
thanks.
