I have a 60hp Johnson (J60PLSSE) that is having an issue with the TnT. When I try to raise the motor with either the switch on the motor or the throttle controls, it will only raise it about half of what it normally goes. It goes into the tilt part of the TnT but it doesn't go high enough for the trailer lock.
I can hear the relay clicking on and off when I hit the switch on and off. When the tilt stops on the way up, the relay clicks off well short of where it should. Is there some adjustment that can be made to control when it goes on or off at its limits?
Also when I lower the motor, it goes all the way to the bottom out position without the relay clicking off. If I keep holding the switch on, the tilt motor continues to run. Is it suppose to stop automatically at the bottom most position as well?
Any ideas on what may be causing this behavior?
thanks
Bill
thanks
Bill
