BRBHorizon
- Sep 13, 2016
- 28
First of all I'll introduce myself as this is my first post...
We just bought a 1999 Four Winns Horizon 180 BR with a 2000 130 Johnson, it has an Aluminum 14.5 x 19 prop..
All was well at first but then I started having some running issues. As part of the diagnosis I have taken the fuel tank etc out of the equation by running (last night) on an auxiliary tank. I suspect I have a bad anti siphon valve so the whole fuel line is being replaced. The boat/motor sat for quite some time I think before I bought it.
So my remaining issues are...
What seems to me to be a very rough idle. I'm not used to 2 strokes so this may be normal but I suspect not quite. The other is that the specs state top RPMs as being 5500 and I cannot get any more than 4300. I know the tach is accurate because I tested it with a hand held tachometer and it was pretty much bang on.
My speedo says a shade over 40 mph and my GPS says 38 mph (I was going upstream so sounds about right). How does this compare with anyone else with a similar setup?
