2003 Caravelle interceptor 212 fuel sending unit location?
jalvara
Fuel gauge stays on empty...Checked gauges and they are working.properly.. Now im trying to find the fuel sending unit but don't know where to start
Navigator_Victory
Re: 2003 Caravelle interceptor 212 fuel sending unit location?
Heer is a pic of mine....top of fuel tank but,,,,,doubt yours is the same
cr2k
Should be somewhere on top of the tank. Usually under an access hatch in deck if not accessible from bilge. Follow your fuel line back to tank, should be close to the connection.
jalvara
Thanks guys I found it underneath the deck.. one more quick question the fuel tank is currently full.. Do I have to drain all the fuel before removing the sending unit?
Fireman431
No. Disconnect the battery to avoid errant sparking. Remove the 5 screws holding the sending unit into the top of the tank.
Verify the sending unit is bad first, though. Take the ground wire wire off and connect it to the (usually) pink wire in the center of the sending unit. The gauge (with the key on and the battery connected) should peg to full. If not, you have a gauge or wiring problem. If it does, it's a sending unit problem.
jalvara
Thanks guys for all the help... I highly appreciate it... It appears that the floater on my fuel sending unit was inop... Called Wema the company that makes my unit. They told me that I would have to purchase the whole fuel sending unit since they do not sell the floater by itself ...
