2005 Johnson 15HP 4 Stroke will not accelerate. Could it be the prop? thrust bearing?
Hi guys, I have an issue with my motor. Outboard motor runs great but I can only go about 1 mile an hour. If I give it any gas, it does not move forward, it acts like it is in neutral. Engine does not overheat, water pump spits out water fine, and I see water coming out of the prop area. Out of the water, with engine off in neutral, the prop moves freely, when in forward or reverse, prop moves with some resistance. I don't see anything out of the ordinary in the prop area. Any help would be greatly appreciated.
