I have a new to me 1994 225 HP Oceanrunner with a powerhead rebuild. I have run the boat offshore several with no problems. Last time out it ran a little hot so we limped back to the dock at 1000 RPM so the horn would not go off. Since I did not know the history of the waterpump, I replaced it Saturday. Put the muffs on and it is stil running hot. Pee stream is pretty weak as it was before. I checked the water inlets and see no obstructions. Any help on what I could do to check for debris or obstructions that is restricting my water flow? Can I 'backflush' the motor.<br /><br />Your help is appreciated.
