The prop seal on this motor is located INSIDE of a bearing assembly....to get to it I believe that I have to remove a brass piece that holds the seal in.....
There is (what looks like) a large screw driver slot on that brass piece.
Am I correct that this brass piece screws out to expose the seal....?
The only way to buy this seal is to take it out and measure it and buy one at a seal house....
It's not listed in tthe parts list itself.....
RACEONE told me that I could take it out and measure it to replace it....
Raceone...could you please tell me exactly how to get to the seal?....
Am I right about the screw driver slots....
Actually I believe that a thin strong piece of metal will work better than a screwdriver......the slot is quite large.
Many thanks
Many thanks
