Re: 262 Vortec V6 timing issues, sorry a bit long
The modules don't know what they are installed on. A V6 will work on a V8 and visa versa. The amount of advance and the actual curve does change a little, though. That is because the counter/divider is different. 6 pulses = 2 rpms on the V6 module. There was info in Dennis Moores book on using the V6 module on V8's. Using a V8 module on a V6, I think would have a slightly delayed timing curve.
Timing curves: http://www.boatfix.com/merc/Bullet/95/95_11.pdf
Also can you use a V8 module on a V6? I don't know how the module knows wether it is on a V8 or a V6. It simply reads the pules from this distributer and fires the coil. (ok, it does a little more but that covers it input and output)
Thank you all very much,
Cameron
