Not getting fuel to carb. put intake from gas can directly to pump still no gas. Wondering if I should replace the pump or does the filter in the pump need to be replaced? Also should I be able to blow through the inlet gas line that connects to the fuel pump back into the gas tank with ease. I tried but it was really diffucult. Also is there a filter in the tank that can be checked and how do you access it. Thanx--Bob Can you tell this is my first boat? 19 Ebbtide 4.3 mercruier alpha one
