lilmandavis
- Mar 9, 2006
- 618
will a 2bbl holley be ok for a big block if im not racing someone? what size jets should i use? will i burn up pistons if i run a 2 barrel?
 Because automotive engines don't operate like marine engines do.<br />When was the last time you seen a 454 automotive engine run at full load, in low gear, going up a steep hill at 4500 rpm all day long.why do the automotive 454's hav a 2 bbl tbi? im askin just for kicks?<br />
The Merc./Weber/Edlebrock/ Carter Clones are only spread-bore in the 625cfm Carb......<br /><br />The 750cfm is a standard Square-bore..........<br /><br />Not that it Matters,...... Boats Burn Massive Quantities of Fuel,.....Regardless.....especially if it is a spread bore type like a Q-jet, or an edelbrock/weber.
