Serial # 6e9 402225 el 40hp 2 cycle 2 carb. I'm having a problem with the carb settings for this motor.I just rebuilt these carbs. I have gas that leaks from the main nozzle and while idling, the motor vibrates the choke closes and kills the motor. Other post it says that I might have a faulty float or needle that doesn't sit correctly to shut off the fuel? From the schematics i can see that there is a slow jet also. Should that be adjusted or closed shut?
Any help would be appreciated.
Also new member, please go easy on me.
