470 blowing white smoke
Eagleridge5
I've had this boat for 15 years. Mostly it runs well but recently I've been noticing the coolant reservoir getting empty but no noticable leaks and oil is good. Yesterday I noticed a lot of white smoke coming from exhaust, it started heating up so I shut it down. The reservoir was half full after a few minutes. Does it sound like coolant getting into the exhaust?? How is it doing that??
airdvr1227
Re: 470 blowing white smoke
Cracked block or bad head gasket would be my guess. Pretty common in the marine world.
EddiePetty
Have your cooling system pressure tested. More than likely you'll find a defective head gasket, a leak in the heat exchanger or a defective gasket between the exhaust manifold and elbow. As you have a closed cooling system, and live in sunny California, a cracked block seems very remote.
The cooling system pressure test will isolate your problem. :)
6meter
White smoke = your burning coolant, as well as fuel.
rodbolt
yes pressure testing not only the cooling system but individual area of the cooling system is mandatory BEFORE wrench twisting.
the original cast iron manifold had a tendncy to crack back near #4 cyl and dump colant into the exhaust as well.
thats what the AL manifold kit came out to correct.
the manifold assy can be tested seperatly from the block assy.
a leakdown test can quicly and efficiently find head gasket leaks.
stonyloam
All of the above advice is good. You can get the tools for the cooling system pressure test and compression test at Autozone. They will lend them to you for free. Pull the plugs, if the ceramic tip is white (rather than tan or brown) it is a sure sign of coolant leaking into the cylinder. If you have to replace the head gasket use an OEM Mercruiser gasket. Good luck.
zbnutcase
Look at the manifold to riser/tank gasket joint. Any signs of weeping or leaks? If so, that would be the first place to look if pressure test shows leakage, especially problematic on the aluminum manifold engines.
Don S
If your 470 ever overheated, a blown head gasket is a very common problem due to the open deck design of the aluminum block against the cast iron head.
stonyloam
Even if it has never overheated:rolleyes:. Mine never did. The head gasket was not "blown" but sure was leaking coolant into the cylinder.
Eagleridge5
I will try the cooling system pressure test and check the plugs this weekend and let you know what I find out. Thanks for all the replies.
guyaverage
x2
Mine never overheated either, just a few wisps of steam every so often and a very slight loss of coolant. The head and deck checked flat as can be. These engines have an appetite for head gaskets like no other. I've seen small block Chevy's practically catch on fire they were so overheated, with no problems. You stand near a 470 with a slightly warm beer and that gasket goes bye-bye.
