natemoore
Master Chief Petty Officer
- Jun 13, 2009
- 844
Last season, I read the sticky regarding this topic and meticulously followed the Merc manual's adjustment procedures several times on how to adjust the cables. I recall that it wouldn't even shift into forward (or was it reverse) as a result. So, I just did what it took with the adjusting bolts/turn buckles to get it to shift into and out of gear.
But, I have to go slightly into reverse to get out of forward and slightly into forward to get it out of reverse. The switch is killing the engine, but not quite at the proper place.
Question 1: Do lower shift cables ever stretch, making adjustment impossible, even if done "by the book."
Question 2: Is it possible to simulate the load on the prop with the engine off by using bungee cord to hold the dog gears tightly together?
This way, I can visualize what the shift plate is doing as the control lever is moved back and forth and hopefully do some tweaking.
