flyin_bryan84
- Aug 29, 2007
- 14
i have a early 80's model 50 horsepower mercury. i have replaced the whole electrical system from the key to the spark plugs. now i have the timing right on. i can get the motor to start in high idle. i have adjusted the primary and secondary screws form on end of the spectrum to the other and i cannot get it to idle down below 1200 rpms. here are were the questions start...
how do i get it to idle down to the 600-800 rpm area i need to shift into gear?
can the reeds go bad?
how do they go bad?
if they are bad, what things do i have to do besides remove and reinstall new ones?
are there any brand of reeds that are superior than others?
how many reeds does this motor take?
are the reeds my problem?
has anyone had similar problems and how did you fix it?
any information is helpful
thank you
bryan
how do they go bad?
thank you
bryan
