Re: 57 35hp over-rev then no spark
So I got everything back together and still no spark. Took flywheel off again and meticulously looked at everything one more time. Cleaned and filed points, set gap again at .020, tightened all connections, checked for any bad wires, checked coil to boss spacing, everything checks out. Put flywheel back on and check for spark. Nothing.!!!! opened point access in flywheel and adjusted points to .018. No spark. Reset points to .022 and had weak spark across 1/8" gap. Decided that was a victory and called it a day. Is there anything I could have messed up when I had the armature plate off the motor that would affect timing? All the parts under the flywheel look brand new.
