How can I tell the difference between a blown head gasket and bad compression due to a worn cylinders and worn rings ? What are the signs of a blown head gasket vs worn cylinder and rings. I am experiencing 1/3 RPM at WOT (Only under load) and I have checked the fuel lines, fuel pump and cleaned the carbs, but still no luck. Any ideas would be appreciated.
Thanks
Thanks
