alittledinghy
- May 15, 2003
- 83
i have a 1961 75 HP evinrude serial number 03158 ,model number 50927<br /> and the previous owner disconnected some of the wiring in the helm. the #8 or #10 wire from the Gen. to the ameter is still connected , the three wires to the ignition swith are connected and the boat starts and runs. My questions are these. Where does the other end of the ammeter connect ? there is a piece of # 10 wire long enough to reach the fuse box still attached to the Batt. side of the ammeter, but not currently connected to it. Is this where the 12 volt supply for the fuse box is taken from?<br /> The "Seloc "manual leads me to believe that the other(batt) side of the ammeter goes to the + battery . Should this be wired directly to the + battery terminal or thru/connected to the Unicharger control box in some fashion ? next question : Where exactly does the tachometer (Sun super tach II) wire in ? i know which wire is which on the tach., but i dont know where to connect the blue tach. pickup wire to the motor ? jerome
