mydejavooo
- Sep 14, 2011
- 22
Ok, I am needing some help and some support. I juuuuuust bought a 65 MirroCraft with a 65 18hp Evinrude...and I have taken it out a total of 3 times. The first time was great; no problems. Second time I took out the boat alone after having installed a hydrofoil, and it was even better!! Today I took it out with my 10yr old son and 9 yr old daughter...and I started having some issues.
First, I noticed that when it would get revved up to it's highest rpms, it would suddenly slip like you threw it into neutral. I would back off the throttle, and it would "re-engage". But this issue continued for a while, and I couldn't get it up to full speed as a result.
Then, I was trolling around fishing with the kids, and then accelerated from a slow troll. The engine sputtered a little and died. I immediately tried to start it (manual starting only) and it felt like the engine was stuck! The flywheel would not move at ALL. I removed the cover, noted NOTHING, and then tried again. I was able to pull it maybe 3 more times, and not it's STUCK again. $#$%@#$!!!
So my questions is this....what is going on here?? I had to paddle about 3/4 of a mile with the assistance of my son, and the poor guy was tuckered out!! I got home, threw the boat in the driveway and called it a night. :facepalm:
Is my engine fried?? Did it overheat and melt the pistons? Did the fuel pump go out?? I have NO idea what to do, and this is the first outboard engine that I have ever owned...and it's like the curse of the boats has continued once more. I had a Glastron 2 years ago, and I had nothing but problems with it. I just PRAY that someone can offer some advice on what to do, what to look for, and ANY support!! PLEASE, PLEASE, PLEASE!! The engine gave no indication that there was anything wrong with it, right up to the point that it died and is now frozen. No billowing smoke or noise.
DeJa
DeJa
