Re: 69 evinrude 18 hp no forward motion.
Ok so it was a gasket sealer made by BRP or whatevaa.LOL.
I mounted the evrything back togethere and i totally dunced it. I used the triple gaurd grease for the top of the crankshaft splines instead of the moly lube that came with it.
IS this OK????
started it up and ran for like 45 seconds with no water coming out , thought i blew and messed up then all of a sudden it just starts shooting water. YAH YAH!!!!
Of course I now have a new question .When i finally got it up and running it is only holding a Idle in full throttle. Actually after it warmed up it held idle in a little less than full throttle.It has always kind of ran this way. read somewhere that these old e-rudes dont idle all that great.(or just rumor???)
my questin is how should i start diagnosing this.
( iam turning to the manual now but thought you guys might have some insight)
Also i am running the motor in a bucket and i want to check to see if the shear pin corrected the problem as to why the motor wouldnt go in forward. do i just click it in gear at low throttle/idle (if possible)in the bucket?????
Thanks ,there is no way this project would be near complete if it wasn't for this forum. Much respect to all those who contribute around here.
B stroH
IS this OK????
B stroH
