7.4 merc won't start after winter storage
ESGWheel
I am glad this is getting sorted out. One more question if you do not mind. What is your normal cold start process?
Thanks.
timharper89
Thanks.
Usually pump the throttle a few times and then crank... something else i should be doing?
ESGWheel
That is the way I would do it too. However, I was thinking that if still does not start as expected yet all else is good, to try an experiment. At the next cold start do only one stroke and start. And if no joy, then at the next cold start try 2, etc. Just an idea, perhaps a crazy one… :cool:
tango13
my carbed 7.4 is an absolute bear to start after not being used for an extended time. I usually crank for 5-10 seconds to fill the bowls, pump twice and leave at quarter-ish throttle, and then crank again, and it usually fires. Sometimes it cranks a little longer with extra pumping.
When im at the lake for a few days and im running it every day, one pump back to quarter throttle and a bump of the starter - fires instantly!
Had a hot start issue where it wouldnt fire after sitting post-shut down. Mechanic played with it and ruled out flooding, and we ended up changing most of the ignition components (sensor, cap, rotor, wires, and coil), and it made a huge difference.
My experience with the big blocks so far is that they aren't as forgiving as the smaller engines when it comes to starting, from what I've read its just the way it is?
