Re: 70hp Evinrude need year and info
Hello to the 83 Evinrude owners! <br />I have the 50 hp model. Mine sat for 4 years. The carbs were heavily gummed. As were the spark plug wires. <br />Also, at first it seemed like there was a lot of electrical problems. In reality, there weren't, I just needed to remove a lot of connections, clean them and put 'em back together. <br />Also, get a manual. Very helpful, both in confidence and knowing which part goes where.
<br /><br />Good idea to replace the impellar. One trouble that I had was making sure the water tube fits in the impellar housing when replacing the lower unit. That is the tube closest to you that goes up into the powerhead. The tube is wiggly and loose, so it's easy to miss.<br /><br />The biggest thing (IMHO) is to make sure all the gummed up, nasty old gas is out of it - through-out the fuel system. <br /><br />GOOD LUCK ! ! <br /><br />Jason
