i tried to start the motor for the first time today and it cranks over but will not start i dont know if i have to have it in neutral or not since its the hydro-electric shift and i had to use toggle switches to make it shift when i cranked it i know it went into reverse but im not so sure about neutral when i hit the switch for neutral it went backwards but real slow when i hit the switch for reverse it went faster but either way it wouldnt start. and on my remote there is a lever that you pull up to start and down to run when i put it in the start position it wouldnt do anything no crank or anything please help im losing my mind here.
