Re: '73 chrysler 105 surges at WOT then looses power
Good to know Frank, Do you mean the locating pin for the crankcase halves?
As you can probably tell from the photos i've already removed the lower crowl. I may remove the lower leg to make it easier to crack the midleg off.
I'll see if i can find a impact screw driver, failing that ill just drill them and use a easy out. (reverse thread tap of sorts)
