Frank Acampora
- Jan 19, 2007
- 12,004
Re: '73 chrysler 105 surges at WOT then looses power
Chrysler and later Force used the same rods in engines 20HP and up so yes, you can mix and match rods. If you look, there is a ground tab on the top which the factory used to match weights. Once I did weigh a number of rods and the all came within 7 grams. However, if you do get the stub bolt out, there is no need to replace the rod(s). as long As the threads or the cap breaks are not dicked-up, they will be good. You did match caps to rods and did align them before torquing the bolts, didn't you?
The only caveat though is that early Chrysler rods --before 1970 --had a captive pressed in wrist pin and two needle bearings in the piston. Obviously, you can not use these rods. After 1994, larger late Force engines of all sizes except the 75 had longer rods, larger diameter wrist pins, and the wrist pin hole set higher in the piston so again, they are not usable for your purposes. Stick within 1972 -90 and you will be safe.
At 20 foot pounds, you may or may not have stretched the cap bolts. They are aircraft quality and probably good for 180,000 PSI tensile strength but I am not an engineer and don't have the formula to figure out torque to psi conversion. In your case, as you said, it is better to replace them now. Again, the same bolts were used from (in this case early '60s through at least 1994.)
