'76 Holiday i/o 18' Fishing Rebuild (pic heavy!)
Watermann
Cut a patch piece of AL, paint it the same, cover holes and clamp it on with some 5200. Put a matching one on the other side to make it look factory :lol:
italianstal27
Any chance you have a good written description of how to install the throttle linkage, steering, etc.?
Hard to find any youtube videos starting from scratch...
italianstal27
We're still in it... barely. Running on fumes
Antennas installed. They'll be just in front of the windshield. Hopefully the VHF dosen't whip the windshield too hard. If it does, we'll add foam.
Radios mounted. They're in there SOLID but still removable. Mounted them level with the floor, then added 1/8" slope for water to run off if it happens to get inside. Highly doubtful. Both radios are covered.
Almost done with wire management... I wish I had taken a picture of how much wire was hanging out. All of it is hidden behind the gunnel & zip tied down. Makes it clean + easy removal. Still have a little to do obviously, but much much much better than it was earlier today. Will have to remove everything to run fish finder cable, but the hard work is done. Now it's just removing 1 zip tie at a time to run another cable.
Will need to redo the wire management under the console. We got the throttle linkage mocked up and it clears the steering wheel and driver seat! Huzzah! Need to take the linkage apart and clean it. It's super gritty past half throttle.
Progress! There'll be a 2x2 that goes between the throttle wood and the gunnel to help seal it off.
The new bushings for the rear engine mounts arrive today. So we'll be pulling the engine hoist out... again... and hopefully having the new bushings gets the engine alligned!
-John
italianstal27
Still having problems with the LED strip lighting I did. I think the problem is using 16 AWG wire. Whenever the wire moves it really pulls on that small solder pad. You can see starboard is off but port is on. Trying to determine best course of action to fix. Right now, I'm at cutting to the next solder pad and soldering some 22 awg wire and then butt splicing to the existing connection.
I also have slight concerns that the ground wires may be touching the painted hull. So both sides may get redone. Sucks, but it's how you learn.
Now the good news.... the led strip lighting I can no longer get to DOES work! Thank God. 100% would have been hosed if those had decided to intermittently work.
Also decided we need to light up the bow as well. So ordering some more white lighting. Going to also add some lights in the engine bay. So plenty of opportunities to practice soldering these wires again lol.
We decided not to add red lighting to the bow. However, making it happen would be very easy. So we don't have to decide now!
italianstal27
We got the bushings out last night for the rear mounts, and boy was that challenging.
Using a 15/16" socket with a hammer finally did the trick. Although we did take an air hammer to it hoping the vibrations would help work things loose...
Tonight we'll try and get the bushings back in. New mounting hardware arrives Thursday. Sierra part # 18-2141 for anyone interested.
-John
italianstal27
More progress.
Use the mechanical connectors for LED strip lighting. It saves SO much time. We also got the new bushings in and our old ones were DEFINITELY sagging. Easily the reason why our engine coupler wouldn't go in.
And here's how I pulled the bushings in. Used a 7/16" rod and 2 sockets. 1 socket on each side of the flywheel housing.
Both sets of LED lights work now, and I'd say it gives PLENTY of light in the boat to see where you're stepping. More strip lighting arrives tomorrow, and I'll use that to light up the bow.
Today, we'll inspect the stern drive, replace water pump, attach bow cap and anchor caddie, and install blowers, horn, and bilge pumps.
Day after, when mounting hardware arrives, we'll allign engine, attach stern drive, and then start building the scaffold for the stern deck to sit on.
Quick question for people who've done this before, how easily removable is your stern deck and the supports under it? If we need to do an engine swap, will we have to come up with a clever way to lift the engine out? Or is there a method for having a removable stern deck?
-John
Watermann
When talking about a "stern deck" I assume you're referring to the transom cap that goes under the rubrails and end caps. No way I know of to make it removable quickly, you have to dismantle the cross brace, supports, rubrails, trim and end caps again.
The section with the vents on it in my Chief pic below is the transom cap.
y4mzGAMvpzbfFYjct7RjhERjcGtIB_PMC5O4ch84CTdtW4pEtnl-IwDEcCgak8j8ylZRqIsI9b-wZ9uxKagjMaYyJ3GDlmpmSKCQCODfTFuJC5sgnG2SxI_eZ9AfdK_dqfQO1TLmdzA5J7Uszk66xv_1Ricf3ylIowRt4BEk21Rjxo_wBUjobP_A4o-h0simRlGFeUas8kZq4qT11IHK9AJjQ
italianstal27
Hmmm ours is enormous compared to yours. Like 17" wide. In that case we'll just have to get creative on pulling it next time ;)
Watermann
No my motor is enormous compared to yours, :lol: the transom cover is around 1-1/2' wide.
italianstal27
OH SWEET JESUS THING IS YUGEEE.
Watermann if you were to pull your engine how much would it suck? Especially because you're rocking that chieftan which I'm sure is taller than our Holiday... but say you had an engine hoist tall enough... would you be able to pull it?
Watermann
Yeah easy enough to pull the motor, I know a guy who has a couple boom trucks so it'd be a morning job.
italianstal27
Anchor caddie and bow cap installed. Also attached the bow deck 1x4" supports to the aluminum.
We bout those green/red LED strip lights for bow markers. those'll go under the rub rails. already have 2 holes drilled in the boat :'( from previous construction of course, so we'll route the wires through that.
Decided to add white / red lighting in the bow.
We also realized that a 1/4" bolt fits perfectly into the windshield mounts. We just need to grind down the height of the hex head 1/16". Most people use weather stripping from home cheapo to put their windshields on right?
-John
Watermann
I used the EDPM marine WS rubber from HD for my SS and it worked just fine.
italianstal27
Huge progress!
Trim pump in! Although I think I have it hooked up backwards.... so we'll flip 'em.
Dual batteries fit, but need to start thinking of what battery tray can I fit back there. 2" of space between the edge of the deck and the hydraulics.
And sterndrive in!!! The alignment with the new mounting hardware fit 'kinda' close, but we had to release tension on the rear mounts. Not torqued to 25 ft-lbs. After raising them a little, the alignment bar went right in.
Next we replaced the water pump. (remember to drain your oil!!! We learned that one the hard way).
Had difficulties getting the stern drive on. Decided to try the engine lift, and BAM slid right in. No problems, had to barely even push it in. Shoot it almost slid right on... So even though our alignment wasn't picture perfect (took 3 fingers to push it in), we did pretty good!
-John
Watermann
It's not how easy it is to push the alignment tool in and out, it's that the grease marks are even top and bottom.
So you split the OD case open with it still full of oil? :lol:
How'd the oil look any water?
italianstal27
Outdrive good! Only a small sliver of chocolate milk came out. Which is weird cause it should be blue... So someone must have mixed lubes before us...
Got the Home Depot seal. Found it by all the window sealants. Basically the only one available for marine or automotive.
Huge progress today. Electrical is done... Except the washdown pump which will come later. Horn in and it is LOUD. Getting to spray the corossion protection is SO satisfying...
Tomorrow we may get to hooking up throttle and shift interrupter etc.
-John
italianstal27
Added a 12V outlet and 2 USB plugs... located next to radio. One is 1A the other 2.1A, so basically one person can charge their phone and the other gets a trickle charge. Have a lot of stuff on 1 16AWG ground running from starboard to port. I have it fused at 20A, so we'll see if it blows. If it does, we'll run another wire and split the load in half.
And the tales of sadness continue. I didn't leave enough wire to hide it under the gunnel :(. Whatever distance you think you need, add 8" to it... Being a couple inches short sucks.
So, ended up soldering and heat shrinking a 7" splice into both wires. No problems.
Bow now lit up! So there's plenty of light in the boat now for those early early mornings... Also, we added the port/stern lights in the front. LED strips below the gunnels.
Blowers and both bilge pumps installed. We got a second blower for $5 so we decided to put 2 in. No reason, just wanted it to sound like a tornado when we turn them on.
We have the trim pump reversed, so tonight we'll fix that, test if the limit switch works, and then start hooking up the shift, throttle, and steering cables.
Probably splash this weekend if the stern drive shifts into Forward / reverse and the engine runs fine?
-John
