'76 Holiday i/o 18' Fishing Rebuild (pic heavy!)
italianstal27
Will wait till 9 tonight to see if it's working...
Thoughts and prayers <3
Who knew that a stupid hydraulic hose would be what kept us from splashing today...
But you certainly don't want to be spraying hydraulic fluid into the waters. That's not ok
italianstal27
From earlier though.... when expectations were high!
IMG_20171026_091212.jpg'
Winching the trailer out
Departing
Kicker was definitely jumping all over the place when we were driving... does anyone strap their kicker down? or do you let it bounce? We've got the biggest 2 stroke bracket you could get from panther...
Actually winched the stump out we were using to pull the boat with... so then we had to reposition lol
italianstal27
JB weld did not hold up to the steering wheel moving. Broke the seal when we moved the stern drive. So we really just need a new ram. Sucks.
italianstal27
So we're on our way to the Bay :) going to use the kicker.
We'll throw out some crab traps and troll for salmon or maybe plunk. Going to get the engine idling well in neutral and play with the carb a little bit. Won't put it in gear above 1200 rpm... That's what the manual says anyway and it seems it's a heated discussion on the internet lol.
So it's kinda a splash! We're gonna look for a used ram to replace the bad one.
italianstal27
6AM getting ready to haul out!
24 Crab!
Trial by fire in Tillamook bay!
Today we're heading to the Columbia to hopefully catch some Sturgeon. Today's the last day it's open to retention.
Boat is doing well. We met up with our friend's at Fairview marine and got a new hydraulic ram last night. Plugged it in and we're good to go! Bled the line by raising the pump 5-6 times.
Got the photo tachometer out and the boat is idling at 400 RPM!!!!!! MOST GLORIOUS SUCCESS.
We'll get her in the water today and actually use the main engine, not just the kicker :D :D :D
We do have a small leak somewhere... every 2.5 hours the bilge turned on for maybe 3 seconds? But we've read most everyone's riveted boats leak so we're not too upset... Maybe we'll give it some time and see how it works :)
Day 2!!
Watermann
Great to see you guys got out to fish, good luck is bound to be due!
italianstal27
Hello from the Willamette river! Our lower shift cable is shot I believe. We could only shift into reverse and could only shift into neutral after killing the engine. After pulling the Lower shift cable, we found that it had full travel all over the place...
I suppose that means we need to replace the lower shift cable... Which sucks because we didn't and watermann told us to. Symptoms of a blown lower shift cable are that it travels up and down no problem right?
BWR1953
Congrats on the splash! :rockon:
Those crabs look yummy! :hungry:
And yes, listening to the sage wisdom of El Supremo Watermann is always best! :joyous:
italianstal27
Found the problem. The retaining screw had come undone. Not sure why or how, but we'll reinstall it and see if we can shift ok again! (most likely yeah). Might have been a step we missed when reassembling. The previous owners did some funky stuff I tell ya....
-John
Watermann
You have to tie that screw up with some SS wire or it will back off again.
italianstal27
Alrighty she's good to go!!!!! Sucks that it's Sunday and now we have to wait till the weekend to try her out 😢
italianstal27
Pic from our trip to the Columbia!
Even though the sterndrive wouldn't engage still had a great day on the river. Even if things don't go perfectly, you can't let it get you down :)
Obligatory dual battery pic <3
italianstal27
Aaaaaaaand the rain has begun.
Going to be working in 3 day stints most likely. Having to cover / uncover the boat is going to suck, but I think we were spoiled having that marvelous tent and siding with house to protect.
We're still working on the boat cover supports.
-John
Watermann
Yeah our weather up here in ME WA turned too, wind and snow :grumpy:
italianstal27
After a long winter (not really Oregon had a super super easy one), we're ready to finish this girl!
Tomorrow we pull the cover and see if the engine fires up. We drained the block in December but didn't fog it... Hopefully we don't need to do a quick carb cleanout ;)
oldrem
Best of luck to you. Sure wish our winters were that short here.
