76 johnson Sea horse water question
Jdude1
I replaced my impeller and I'm wondering how hot should the discharge water be it is pretty hot but not hot enough that I cant keep my hand in it. model number is 25RL76E - Thanks in advance
F_R
How hot?? What you said. A better indication is, does it pump at all speeds, especially at dead slow idle.
Jdude1
yes it is pumping at idle , but how hot should the discharge water be? if its too hot could this be an indication of a problem with the impeller - i have had outboards in the past where the discharge water is warm but this is pretty hot
Jdude1
:faint2:AHHHH the THERMOSTAT I didn't think about that - ugggh I'm taking the boat out sunday I'm goin to have to take it out clean it and out and use some high temp gasket maker for the cover seal if its bad - i don't have time to order the parts :(
Jdude1
So what is the best way to clean the thermostat? - Thanks:)
kbait
Once warmed up, check temp of cylinder head. If it’s cool, thermo stuck open, if finger becomes uncomfortable after a couple seconds, perfect.
Jdude1
ok will try that and if its stuck open i should be able to clean it with some solvent correct?
iggyw1
Ensign
You can remove the thermostat and check it in a pot of water on the stove. Check at which temperature the stat opens at, and see if it closes properly as the water cools off in the pot.
F_R
9 times out of 10, if they fail, they fail open. It would be unusual to save one once they do.
Once they fail, the wax pellet is damaged. To repair is to replace
Jdude1
can I still operate the motor if the thermostat is open? Iam leaving sunday have no time to get the part:embarassed::eek:
Jdude1
I'm still not convinced I have an issue the motor was getting warm I only ran it for about 8min but the discharge water was hot maybe I should run it longer to see if it cools down?
kbait
If discharge water is hot, it’s pulling heat out of the powerhead. This is good.
oldboat1
Check surface temp on top of the powerhead, as suggested -- monitor it that way until satisfied it's not overheating. If it exceeds 160F (overheating), it will be too hot to touch. If you can pick up an IR gun, check it with that (operating temp around 140F when warmed up, give or take.)
