Re: 77 Johnson 115 won't hole shot without choke
Hi Phil,
Thank you sir for that info. I appreciate the time it took to write it all out. Great info!!
Well, finally got time, it was a clear dry and sunny afternoon, had the boat in front of me, no sweety wanting to go out to dinner, so off came the carbs again.
Took a few pics, wrote down some jet numbers. Maybe I will get lucky and stumble over what's causing my little motor to behave badly. This motor on my 15 foot boat would stand it on the transom and be at full speed once the bow settled, usually it took all of two or three boat lengths.
Still could not find what is causing the crap performance, gaskets looked good, no nicks or debris smashed into them. Looks like the carbs have 1 and 3/16 bores on them which is what the micrometer was showing as well. The idle jets are 36's, and the mains are 260's. A regular Craftsman multi driver is perfect size driver to get the jets out.
So, took a few pics, blasted ever orifice with cleaner. Tried to get a visual on spray patterns through the various openings and jets. I couldn't tell that there was any difference between the same openings of either carb. Made sure the upper passages were clean. I think this is what was talked about and mine were spotless, see the pics and let me know if I did right or not.... Basically, put it all back together again. I did change out one of the choke solenoid fuel lines since it is easier to get to the bottom carb once the top one is off.
Kind of late tonite to fire it up, so tomorrow will have to wait and see. I'm getting it wet first light.
There is a vacuum (pulse line) line coming off the base of block and goes to the fuel pump. I can't tell if it was not replaced or not and I know I have not replaced it. For that matter, it's a tight squeeze to get my finger underneath the block to feel where it stopped. Within a fingers length, so that should be doable some how. I am thinking if it is still running like poop in the morning, this is my vacuum leak and I have to figure out a way to get underneath between the block and case to pull that hose off and push on a new one..
Thank you all for the help and info, it is much appreciated.
Greg
