Re: '78 Ebko Lebaron - Therapy
Lunch break!
While I eat and cool off...give you all a little update....
Got up at 6 am...rolled out the compresser bout 6:45...started sanding.....guess I got about an hour in and the airfile started sticking real bad...as in not oscilating....would slow down...bumped it and work again for a few...then back to sticking and stopping...put some oil in it.... the model I have is an older high dollar one...has place for oil on side....plus I have been putting oil in the air inlet...seemed to help for a little bit..thyen started slinging oil all over the place..this is when I realised that the side oil was for the slide...just keeps oil on it....so...wiped it off till clean...and the thing was still acting up so headed to HF for a replacement...this thing brand new was lsower than the old one when it was acting up
....so...started thinking....and connected the portable aircompressor to my big tank...lots of volume now...and the old file runs fine...the new one still slow.....store only had 2...not chancing taking it back and doing the same thing...so..took the shoe off the new one and put it on the old one...still cheaper than a new shoe from the local auto pint place...and now things are working good.
The compressor does run hot though...put it in the shade didn't help much..so putting a fan on it see if that helps...not sure if it keeps shutting off from heat or what..when motor slows down..has a bad cluck..could be the loose belt...
Forgot to mention....this thing will smash the carp out of your fingers if you put them in the right place while it is running!
I sure hope I am using this thing right though....so far just doing one side...more pressure on the leading edge of the glass i put down on the keel...45 degrees one way....back and forth...then switch to other 45 degree...back and forth...seems to be working...just don't want to introduce waves...finding I have alot of low spots that need filled...I'm guessing if over 1/16" I need to put glass in them...lower I can go with filler?
Hope everyone is having a good weekend!
