Troop good luck with your new equipment. You look like you will have a busy weekend! keep up the good work.To end the suspense....
5 gallons of gelcoat - check
1 gallon of PVA - check
2qt pressure pot - check
line dryer/cheater valve/teflon tape/cut off valve - check
New respirator cartidges - check
zoot soot - check
mixing cups - check
MEK - check
gallon of resin - check
rags - check
masking tape - check
gelcoat color - not checked...
scaffolding - not checked...
Well I got a little excited over the nice weekend we are expecting...these are things I will need to finish the gelcoat spraying...but I do have some sanding to do yet...I wanted to try the sytem out though and see if my compressor can keep up...imagine I will be needing to rent the gas unit again...this should keep me busy this weekend in one way or another....
Having doubts about adding a second color to my first attempt at spraying gel... mos worrisome is how the edge lines will work...precautions required...etc...going to put the spray equipment together as I am browsing the instructions...hope I got the right one...it was the cheaper of the 2 models, but has a 1.8mm tip vs the 1.4 on the higher dollar unit...
She has agreed to help me when it does come time to shoot it...baby steps..I'll ask for Kitchen utensils closer to the dateThe only thing missing is the Admirals blender to mix the gell ..![]()
Thanks SBB...I hope to atleast get a trial run in this weekend on some cardboard or something...Troop good luck with your new equipment. You look like you will have a busy weekend! keep up the good work.
Thank you sir!Nice haul on the supplies![]()
Me too...and Thanks a Million...GT!Will be watching closely for updates...![]()
Thans C-T...I just all along think I wanted gel...reading so many posts on how tough it is, and easy to fix...and my painting skills aren't all that great...but I can sand...see this thread for the past 2 months...Hey Tropper, Glad to see you almost there. I am debating on gel or paint. Why did you decide to go with gel? Any good points over paint?
Troop, you sound like you were a kid in a candy store. Nice grabs.
As for the spray gun, the cheaper one is the right one (per wog & yt dr). Wog pointed me at 2.2 tip on amazon, but it did not fit the gun. Yt dr says the 1.8 is fine. I think that will be true for someone with experience, but I plan to find a 2.2 for mine. I think it will make things easier for this novice.
Sea ya...
Troop,
that's the right gun. remove the Air Cap from the gun and post a pic. I want to see the TIP. I really think a 2.0 to 2.5mm tip would be much more satisfactory IF we can find one. Problem with HF is they don't usually sell replacement tips. If I can see the tip I might be able to find you the correct one.
For your stripes read this...
http://www.offshoreonly.com/forums/fiberglass-paint/277561-gel-coat-stripe.html
Computer troubles tonight preventing me from posting pics....trip to Jackson, TN this week....will provide updates tomorow night...I did get the glassing of the hull sides done today....got some things to discuss with the new pressure pot...
