Sea Stomper
- Nov 9, 2010
- 158
Re: '82 Bomber backyard rebuild
I certainly would keep it. I fish a 15 foot 70's Orrion tri hull in the Northwest Pacific Ocean, and I'm keeping it for sure. Next season will by my 6th year fishing it in the Pacific. I did the transom and stringer and deck thing to it last winter. This winter it will be a little hard top and windshield replacment. Nice little boat you have there.
Don't let it scare you. Thinking about it is much much worse than actually doing it. Fix one thing at a time after you rip up the deck. Cheap tools can be had at Harbor Freight. Deal with the transom, and then the stringers and whatever. One thing at a time, work one problem at a time and if you keep it up, you will soon be in a new boat that feels like a new boat and it will be totally on the opposite side of bumming you out. It will be a very warm fuzzy feeling. You can't easily buy a different boat of this vintage without all the same problems being there, so you might as well fix this one up and end up with something much better than you can buy.
I actually got away without bracing mine but it didn't make getting the cap back on any easier. Seems like the demolition was the worst part of it. I used an air compressor and a 90 degree die grinder with small Scotch Roloc 36 grit disks to grind and shape things. It worked way better than the Harbor Freight 90 degree hand grinder setup. The 36 grit roloc disks on the 90 degree die grinder last forever relatively. I'll post that restore job soon after I have the hard top mod done or in progress. Have fun!
