erosenwinkel
- Apr 22, 2011
- 130
I have a 1985 Force 125hp (1258x5a) and I took the prop to get it repaired and now I have forgotten the exact order of operation to re-install it properly. When I slide the prop over the spline and all the way back up against the lower unit it seems to rub up against the lower unit where the prop meets the lower unit (round 3 1/4 inch diameter ring looking area). The original paint is still on the round part of the lower unit so I am thinking there is a bushing that holds the prop out a little bit away from the housing? I don't remember it rubbing (slight rub, hardly felt or audible)the last time I spun it with my hand. Taking it out tonight and I don't want to mess it up. Thank you!
