88 Capri Restoration (Splashed 08/2022)
88 Capri (2022 SOTY)
Master Chief Petty Officer
Just fitting the rear seating areas before I reglass the transom. Haven't seen non-rot back here in a long time.
kcassells
Very Nice! Wet out all that ply and fill the voids before setting back in.
Thanks KC. After the picture was taken they got 2 coats of poly. I need more blades for my multitool to cut out the floatation boxes on each side.
Well cut out the box and the associated grinding and vacuuming time to close up the boat due to storms tonight and tomorrow.
Tabbing in the rear floor area working towards the transom. KC i have learned a few things....be generous with the acetone and resin the difference is huge. Im so glad im redoing some of it experience definitely helps thanks for the tips everyone. I hope to add a few more pictures later.
kcassells
When I could depending on the weather and the area I was working I would hose out the crapola. :**
Acetone is your friend as well as a sander. Do not dilute the resin with acetone.Comprimises the strength of the glass.
Can be used at times to make your fillets smooth.
Looking Good!
kcassells
OIP.s33S8nk5tIW_UE5tFj-d0wHaMG
Lol. No I read many times do not dilute. It just practice and more practice!
I'm planning on hosing her out before I install the rear seating assemblies.
I am still wondering about this winter/summer recipe for resin because of the gallon jugs I have sourced from two places I have had relatively no issues wetting the glass but the green mixture was a bear. Any thoughts please?
Ok Transom redo is complete with no milky color. Im glad I did what I did thanks to the input I received. Motor mounts next tonight with hopes of doing seat bases tomorrow.
Feeling good on this......
