89 Evinrude 40
taylor1
I must admit I'm a novice when it comes to motors and this is my first boat.
Never had much of a problem starting but was left at the dock before fishing yesterday. Cranking but no turnover. Boat was out last 3 weeks ago without any issues. Primer bulb wouldn't stay hard and while cranking it seemed fuel was leaking into the water somewhere from the lower unit but I couldn't see where. Not sure what to look at first. Motor was tuned with new plugs about 18 months ago.
PW2
Re: 89 Evinrude 40
I'm assuming it was turning over if it was "cranking". Did you mean not starting?
From your description it sounds like you might have a broken/split fuel line somewhere. Take off the cowling (on the trailer) and give the fuel hose a pump, and see where the fuel is going
Al-53
Re: 89 Evinrude 40
check fuel lines and also check to see if the carb bowls are leaking...also you may have a float stuck open on the carb..and raw gas going thru the system...
if you see now fuel leaks from carbs or fuel lines...most likely you have a float not sealing shut
Al
taylor1
Re: 89 Evinrude 40
Someone recommended that the float was probably stuck and that I should give it a little "manual jolt." Does that sound like a possible solution or a good way to mess things up? Obviously as mentioned, I'm a newbie.
