Re: 89 Fiesta Vee 250 setbacks, projects, and upgrades!
thanks guys,
the support is greatly appretiated.
looks like i'll try to return the step 2 and 3 that i purchased from mothers. and look for the 3m or break down and wait on the film disks.lol
Ceira,
 this is the kit i used from amazonian
http://www.amazon.com/Waterproof-Changing-LED-Lighting-Strip/dp/B0054U46Y2/ref=pd_sim_hi_2
and the jumpers, wooooo they went from  a half a cheeseburger to 4 cheeseburgers,,, give it time prices fluctuate daily
http://www.amazon.com/LED-Strip-Connector-Conductor-Jumper/dp/B004Q8OBWK/ref=pd_bxgy_hi_text_b
heres some for what i paid
http://www.amazon.com/gp/product/B004Q8OBWK?ie=UTF8&seller=A3UYUTM4BYYNKB&sn=Bay Neon LED Inc
you can get 1 string done with the 4 wire for around 60 cheeseburgers
check out the teak trim on Christcrafts thread,,,sweet,,, and would be a great solution because you dont have the overhang on your seats to hide them.
Chriscraft,
  shoulda coulda woulda but i didn't buy them disks:facepalm:.
if i remember correctly you used the discs dry then went straight to the wax right?
like always my haste creates waste,,lol. maybe i'll put in an order,,,not sure yet
INDASA Rhynogrip Film 6" Velcro / Hook & Loop Sand Paper Disc  |  |  |  |  |
[SIZE=-1]Rhynogrip Film? Features:[/SIZE]
- [SIZE=-1]Rapid application with Velcro / Hook & Loop, for easy on/off Release Paper Increases Productivity[/SIZE]
- [SIZE=-1]Durable "C or D" Weight Paper with high, tear resistance and increased life[/SIZE]
- [SIZE=-1]Water proof paper for wet or dry sanding[/SIZE]
- [SIZE=-1]Closed Coat reduces loading and extends abrasive cutting power[/SIZE]
- [SIZE=-1]Available in 600P -1500P grits[/SIZE]
[SIZE=-2]Part #[/SIZE]  |
[SIZE=-2]Description [/SIZE]  | Package Count
[SIZE=-2]Per Item[/SIZE]  |
[SIZE=-2]Truck Each[/SIZE]  |
[SIZE=-1]7600F - 240[/SIZE]
 | [SIZE=-1]P240 Grit[/SIZE]
 | 50
 | [SIZE=-1]$ 28.25[/SIZE]
 | [SIZE=-1]$ 25.00[/SIZE]
[SIZE=-1]7600F - 320[/SIZE]
 | [SIZE=-1]P320 Grit[/SIZE]
 | 50
[SIZE=-1]7600F - 400[/SIZE]
 | [SIZE=-1]P400 Grit[/SIZE]
 | 50
[SIZE=-1]7600F - 500[/SIZE]
 | [SIZE=-1]P500 Grit[/SIZE]
 | 50
[SIZE=-1]7600F - 600[/SIZE]
 | [SIZE=-1]P600 Grit[/SIZE]
 | 50
[SIZE=-1]7600F - 800[/SIZE]
 | [SIZE=-1]P800 Grit[/SIZE]
 | 50
[SIZE=-1]7600F - 1000[/SIZE]
 | [SIZE=-1]P1000 Grit[/SIZE]
 | 50
[SIZE=-1]7600F - 1200[/SIZE]
 | [SIZE=-1]P1200 Grit[/SIZE]
 | 50
[SIZE=-1]7600F[/SIZE][SIZE=-1] - 1500[/SIZE]
 | [SIZE=-1]P1500 Grit[/SIZE]
 | 50
INDASA Rhynogrip Film 6" Velcro / Hook & Loop 6 Hole Sand Paper Disc  |  |  |  |  |
- [SIZE=-1]6 Hole for water sanding or vacuum use[/SIZE]
[SIZE=-2]Per Item [/SIZE]  |
[SIZE=-1]7601F - 240[/SIZE]
 | 50
[SIZE=-1]7601F - 320[/SIZE]
 | 50
[SIZE=-1]7601F - 500[/SIZE]
 | 50
[SIZE=-1]7601F - 600[/SIZE]
 | 50
[SIZE=-1]7601F - 800[/SIZE]
 | 50
[SIZE=-1]7601F - 1000[/SIZE]
 | 50
[SIZE=-1]7601F - 1200[/SIZE]
 | 50
[SIZE=-1]7601F[/SIZE][SIZE=-1] - 1500[/SIZE]
 | 50
this look like the right stuff? i was just trying to slow down the cheeseburgers from leaving my wallet. too bad they dont sell in a smaller pack. how many discs if you remember did you use on your hull?. i feel like i am all over the board on the red stripe issue.  i guess i need to settle down a bit and get r done.
so to review Budd, use acetone first
best way would to use the discs than wax with woodys
or the alternative would be to use the 3m compound than use the woodys wax.
i like the sounds of how the woodys has done on your rig, and keepin it clean that long would be great
again thanks to the both of you i really appretiate the support. i wont make any decisions till later on tonite,
off to work i go
have a great weekend
