Hi all.
Have a long standing issue with my 1998 90 HP Force (Serial 0E325251). It has been bogging down and dying when you give it gas. If you hit the key when it is bogging, it will take off. It idles great and runs great on the muffs. Here is a long list of everything I have done or had done:
new powerhead - cracked a cylinder, assumed that that was causing this issue but it was not.
all new engine gaskets
new fuel pump
new fuel lines from tank all the way through to the top carb
full carb rebuild (twice, no new floats just needles)
new primer bulb
new fuel filter
checked vent screen on gas cap
cleaned screen on fuel pick up in tank
timing adjusted
new recirc hoses
3 new recirc valves (only the T shaped ones, 2 were allowing air back in)
raised motor (one mechanic thought it was loading up)
At a complete loss here. Got some great tips from a fellow on another board, he suggested I post here too.
new fuel pump
new primer bulb
new fuel filter
timing adjusted
new recirc hoses
