Nickstoyz
- Jun 11, 2018
- 79
So this outboard has been nothing but a headache. Earlier this year I replaced the exhaust adapter plate gasket and other gaskets in there for the exhaust in the cowl problem. Got it all back together and ran great. A few weeks ago I had a fuel problem, wouldn't start. Today I had the time to rebuild the carb and fuel pump and it started right up. So i put all my tools away and start it again. I decided to give her some gas, just high idle. It was running great but then it started to slow down and eventually die. So I try to start it and it barely turned over, just like a dead battery would sound. I was getting water out the tell tale and I felt the block and wasn't hot. The only thing that I noticed that there seemed to be a lot of water coming from the seam the the trim assembly when running. I never noticed that before. I did check the battery and it checked over 12 volts. I'm lost
