AC / DC Amp Meter Question
JCF350
Re: AC / DC Amp Meter Question
captJason; said:
Internally i don't believe the voltage input jacks on the meters are fused... just the current inputs.
Don't know about the others but the Fluke 88 has fuses for both current and voltage.
bruceb58
The Fluke 88 only has fuses for current. One fuse is for the low current and one is for the high. Voltage does not need a fuse becasue it is a high impedance input.
JCF350
Yep your right :redface:
Specifications
General Specifications
Maximum Voltage between any Terminal
and Earth Ground: ..................................................... 1000 V
W Fuse Protection for mA or μA inputs: ................ 44/100 A, 1000 V FAST Fuse
W Fuse Protection for A input:................................ 11 A, 1000 V FAST Fuse
Display: .......................................................................... Digital: 6000 counts updates 4/sec; (the Meter also has 19,999 counts in
high-resolution mode). Analog Bar Graph: 33 segments, updates
40/sec. Frequency: 19,999 counts, updates 3/sec at > 10 Hz.
Temperature: Operating:........................................... -20 ?C to +55 ?C;
Storage: -40 ?C to +60 ?C
Altitude: ...................................................................... Operating: 2000 m; Storage:10,000 m
Temperature Coefficient: .......................................... 0.05 x (specified accuracy)/ ?C (< 18 ?C or > 28 ?C)
JustJason
yeah its like a 50 megaohm input.... to high to draw any current at pretty much any voltage.
