EHardgrave
- Mar 25, 2005
- 56
We are converting from a Johnson 60 2stroke to a 02 70hp 4stroke. Trying to use the same cables just put on the wiring harness adapter.<br />When setting up the shifting cable linkages, obviously in neutral the prop should spin freely both directions. When in forward both cable linkages move (I assume one is throttle and one is gear shift) should the prop lock in forward, clockwise and not spin but can spin counterclockwise? In reverse it locks both directions. Is it easier to adjust these with the motor running?
