Bt Doctur
- Aug 29, 2004
- 19,413
For what its worth on M/C or Cobras, I use a input shaft with the yoke machined off and the shaft undercut where the 2 o rings would go 1/8 th inch undersize.This helps you to see the actual direction on how the motor has to be moved and how far to obtain alignment. using a drill bit or welding rod seems easier than using and reading the grease marks with the actual alignment tool.Once you have the clearance ,then do the grease test with the tool or use an actual shaft.
