I have a 1986 Penn Yan with the 305 ci with mercruiser outdrive and the batteries were not charging so I purchased the best OEM alternator to charge my dual batteries.... Well I pulled the old alternator and the wiring was different from the new alternator....Well I used some common sense and wired it in and mounted it on the engine and she charges like a dream....But of course that was the silverlining on this cloud because I cannot shut the boat off now with the ignition switch.... The old Alternator had two threaded studs on the back side were the new one had one threaded stud and a two pin connection...I wire the positive to the stud on the backside and a purple wire and a red wire to the two pin connection and the ground to a small bolt and screwed into the back of the alternator..... Again this thing is charging awesome....Just does not turn off awesome......Any help would be greatly appreciated..... Thanks....Woody.
P.S.. I unscrewed something that was mounted on the back of the old alternator and it was full of water, probably why it was not charging......That is another story about the water......
