Alternator wiring question
f_inscreenname
Built a couple motors for a boat I rebuilding and have run across an wiring issue.
Due to money getting short I plan on using (if possible) the original #807653 Mercruiser Alt?s. They have 4 wires (as in the picture). A ground and a hot wire but they also have these two wires marked with red arrows. Wire ignition terminal and Wire Battery sense. What do they do and are they needed?
oops:redface:
Don S
Re: Alternator wiring question
No picture ???????
Don S
Yes, they are needed, without them, the alternator will not charge. They are hooked to the regulator.
Don S
What parts?
Don S
The regulator is built into the alternator, that's what those two wires are attached to. All you need to do is add some wiring, very minor amount really.
Basically, the purple wire hooks to any purple wire coming from the engine harness. BEFORE it gets to the ignition which may or may not have a resistor wire or ballast resistor.
The red one can go directly to the main battery terminal on the starter solenoid along with the main battery cable.
f_inscreenname
Thanks Don
Where does the "any purple wire" come from? The boat doesn't have a mercruiser wiring harness.
Don S
The purple wire comes from the ignition switch, and is the one that puts power to the + terminal of the coil.
What type ignition system are you going to be using? Are you planning on makeing your own wiring harnesses?
f_inscreenname
It's a MSD system with magnetic distributor The system is pretty self contained. Just power the box and its wiring harness does the rest including the coil.
So basically the purple wire is a switched wire thats hot when the key is on?
Yes,... ;)
f_inscreenname
And it wont back feed the system right?
I herd that from someone a while back. :confused:
Don S
Merc and Volvo both use that same alternator, and hooked up the same way. It's how they are hooked up, just like it shows in your picture.
