aluminum boat on galv. trailer bounces too much
smokeonthewater
Re: aluminum boat on galv. trailer bounces too much
how some close pics of the suspension components... lets see if we can spot something out of place... maybe a shot of the shock s installed also
slowleak
I picked up a junk pop up camper today to make a utility trailer out of, it had two minty looking but older Uniroyal ribbed trailer tires. For test puroses, I put those under the boat trailer, inflated to the maximum 45 psi stated on the sidewall and the trailer don't bounce at all, when I put the new Kenda Loadstar tires on the camper, (which is far heavier than the boat, it bounces like a basketball. I didn't move the shocks to the new trailer, and I removed them from the old trailer.
Something I can't help but notice is that the Kenda Tires when inflated to 45 psi, feel hard as a rock, yet the Uniroyal and original Goodyear tires still feel soft if I push on the sidewall. All are Load range B. The Goodyear and Uniroyal, although old, do not bulge and round out when inflated. The new Kenda tires round out and this trailer has no where close to enough weight to flatten the tire out where it contacts the road. The Kenda tires either need a wider rim or stiffer construction across the tread. The tread feels thinner than the sidewalls. With one off the rim, the tread area if pliable yet the sidewalls don't give much in hand.
The suspension on the trailer is fine, the issue is the tires, or at least the fact that all of these new imported tires have issues when used on a light boat. I've got 5 trailers now and all use 12" tires, options are limited in this size. With only 3/4 of the recommended pressure in the Load Star tires, I can't put enough weight on the trailer to flatten out the contact patch of the tire.
I have to back the pressure down to about 15 psi before the tires 'look' right. I fully realize I can't drive around like that but I surely can't drive around on tires that are riding only on the center rib of tread all the time.
I can't be the only guy with a light boat on 12' tires having ride quality issues?
smokeonthewater
just baffling... my jet skis on 12" tires (both old and new) ride smooth as can be....
I'm afraid they are stored too far away from me now to go look for the brand of tire tho.
BigDfromTN
Thanks for this update,
Hmmm guess you did answer your own question, The tires are the problem, much to the doubt of some. Seems to me if the trailer rode fine, you changed tires and it bounced like a ball, Tires were only change and thus the issue.
Glad you figured it out!
lckstckn2smknbrls
Now go back to the RV store and show them and demand your money back and get a different brand tire.
JimS123
Two of my LoadRite trailers came from the factory with 12" Kendas - one LRB and one LRC. They both ride fine. I replaced the set on one of them last Summer with Kendas as well. My tandem has 13" tires and i replaced them with Kendas 2 years ago.
I don't think Kenda is the problem. I think you got a bad lot of tires. Yes, take them back.
flowpath
Go out to you trailer and see if you installed the lug nuts backwards
airshot
Well thought I would chime in here, you mentioned the boat sits to high with bigger tires.....can you swap the axle, that is put the axle on top of the spring perch to lower the trailer then you could go to a larger tire that may not bounce. I believe your tire compound is way to stiff and bouncy and agree the tires should be returned to the dealer, however...trailers always pull better with bigger tires so if the axle can be reversed you may be able to kill two birds with one stone.
PS.....did they put a wide tire on a narrow rim? This will make them bounce like crazy...just a thought..
