I believe I read all of the posts about this but still can't troubleshoot this problem to a conclusion. Can you please help ?
I have a Merc 260 (chevy 350) with an Alpha outdrive. The outdrive, shift cable, drive shaft, wiring, trim position + cutout switches are all new. The drive purrs like a kitten. Everything works fine when I run it on the muffs but stalls going into gear (either forward or reverse) when in the water. The only thing I can find is the idle is a little high in idle. (1K rpm) should be 900.Timing, advance are right on. The carb is a receint rebuild no hesitations etc. . No water in the gas.
I have been advised to replace the shift cable. This may actually be the cause, however I am not convinced. For one it is brand new and I do not see any damage to it along its length suggesting it was overheated. AND it works perfectly on the muffs. If it is bad I am looking into some way to verify this.
Can someone tell me step by step how to troubleshoot this stalling issue ? If the cutout switch is adjusted wrong can I jumper it to get it into gear ? Then pull the jumper to get it out of gear ? I have been told that this switch helps going from gear to neutral not the other way around. Wouldn't this suggest the switch adjustments are wrong ? or the cable it trashed ?
I have already read about the theory of what the switches (neutral-safety/cutout) do and how they are built like crap etc etc etc. I really want to get this boat in the water before the snow flies. BTW I already had it to 2 marine mechanics that set it up on muffs and charged me a bunch. Only to find out that the boat has to be in the water in order to get it right. Well this proves it .. Still not going anywhere.
Thank you
OTG
Thank you
OTG
