minuteman62-64
- Apr 12, 2011
- 1,350
.... At least for a boating season?
1982 Mariner, 30 HP. Put back in service last year after 20 years in hibernation. Gearcase oil changed at that time and no evidence of water intrusion. Drained the lower unit yesterday and about 2 tablespoons of water came out, followed by milky brown gear oil. Only about 10 hours on the motor since last years service.
Based on other posts on this issue, I'm going to replace the vent and drain washers and replace the gear oil. Then take it for a run and see if there is still a water issue. However, because of the age of the motor I'm concerned that the seals dried up/deteriorated during the 20 years of sitting idle.
My question is, if there is still evidence of water intrusion, can I manage the situation to get through the boating season (through December around here). For example, a monthly drain/replacement of the gear oil? That would give me some time to think about how much $$$ I want to put into this motor and do some research on the DIY potential for replacing the seals.
Motor use is strictly salt water.
