jigngrub
- Mar 19, 2011
- 8,155
Once again jig u spoke before u comprehended what I was saying all I was saying is we all talk about spending hundreds of dollars water proofing our decks, and then use something that is known to hold water under it, your answer is don't let the foam get wet, and I agree, but yet we water proof the heck out of everything expecting it to be wet, I've got as much right to my opinion as anyone does, you fill yours with 2 part foam I'll fill mine with sheet foam I'm sure we'll both be fine. Can I borrow the big rivet gun by the way
No, urethane foam can be exposed to water for months at a time without absorbing a drop... something you and others on this site can't comprehend.
From a well known urethane foam distributor:
[SIZE=-1]14. Is this foam water resistant?[/SIZE]
[SIZE=-1]Yes, but with the following caveat. The foams that we sell are considered closed-cell, which means that each cell that makes up the foam structure is completely closed off from surrounding cells which prevents it from acting like a sponge. It is completely safe for this foam to be in contact with water for hours/days/weeks and even months with no adverse effects. However, it should never be submerged in contact with water permanently. Over a period of years the water contact can begin to soften the foam and cause it to lose its closed-cell status. This foam is designed primarily to be used as an insurance policy in case of damage/holes that could cause a vessel to lose buoyancy. Pinhole sized openings would essentially have no effect on the foam since the amount of exposure is so minimal but you should always make repairs as soon as possible to keep the foam effectiveness as good as possible. This will be the case with all after market closed-cell polyurethane foams and even manufacturer installed foams.[/SIZE]
You can borrow the rivet guns any time.
