Artificial Intelligence
beckoning
Recently, I used AI for two questions regarding things on my boat (stern live well/aerator & emptying the motor well). I couldn't get satisfaction even from the generic owner's manual. So I asked 2 AI's detailed questions. I was blown away with the degree of detail in the answer. One program even offered to create a document to use that looked very much like a shop manual. Fantastic. I used Anthropic's CLAUDE and Google Gemini. I'm suggesting AI as an excellent starting place. With the AI information, I feel more confident diving in to solving the issue.
alldodge
Have used both and have a slight feel better toward Claude but it want's to start charging. Gemini seems to be just fine but also noted that it misses things, and I've trained it some for my questions
be cautious. most AI chatbots pull data from social media vs authentic sources. That includes places like youtube, facebook, etc.
when I asked very specific questions on material compatibility (things that one in the marine industry have known forever). I get incorrect answers.
aspeck
AI can be a good starting point, but can give you wrong answers, so verify the answers. If there are gaps in the information that it finds, AI will hallucinate (make up data based on probability… lie) to fill in the gaps. Not all AI answers are accurate …
DeepCMark58A
I tried using AI to get part numbers for the fuel filters in my 1990 master craft tried 3 times got 3 different WIX part numbers.
airshot
Using AI for mechanical issues is one thing, but when people start using it for critical life or death decisions and information....it gets real scary !!
rolmops
Ever since I have found out that some comments of mine, not having to do with boats, are repeated word for word by AI. I have started writing in wrong suggestions. I do not like billionaire thieves.
Mc Tool
Ha ! I just been doing (almost ) exactly that ....looking for trans filters for my Rav4 ....got 3 different answers ( generic pictures ) and when I asked the difference between them it said they were all trans filters but for different trans's 🤔.....🐂💩
BWR1953
I use Artificial Intelligence ALL. THE. TIME!
My wife says it's my "new best buddy." :LOL:
If I'm doing something important, I'll direct it to use scholarly sources only and that way it avoids Reddit, TikTok and other social media, but instead starts using Mayo Clinic, NIH, Cleveland Clinic and other such high falutin' places to get better data.
I was working on my boat a few months back, installing a new tilt/trim sender to match my new gauge and I couldn't get the gauge position to match the engine. The Gemini AI turned OG on me and started giving me instructions on how to use my multi-meter to ohm out the positions in order to get it into range. I made progress and the measurements weren't quite right, so the AI said it might be a European part. I then double checked and confirmed it was US. So the AI said "let's try one more thing" and instructed me to hold the sender in my left hand and turn the "tab" back and forth very rapidly as fast as I could for at least 100 times. I did that and the thing worked! The AI explained that if those senders sit around for a long time (like in my garage... it even joked with me about that!) that a thin film of corrosion could appear on the pot internally and the machinations that I went through wiped it clean! That is some real OG stuff right there! 😲:D:cool:
Jeff J
I have run into this too. I googled 2 different things this morning. AI quoted posts from redit and quora. I received an answer from facebook the other day.
I always follow the links to see where the info comes from but sometimes that doesn’t help either. I was looking up something for an old jeep a while back. The link took me to a trusted vendor’s website but I could not find the information the link was supposed to take me to.
redneck joe
i bypass the AI results mostly and scroll down to thelinks so I can think for myself
BWR1953
Here's an example of what the AI did for me this evening. I'll be adding a delay circuit to my Water Pressure Loss warning setup for my Merc 150 XR6. Helpful! :cool:
🛠️ The 555 Timer Pin-by-Pin Soldering Guide
Before starting, map out the NE555 chip. The notch or dot on the top of the chip marks Pin 1, and the numbers count down the left side and back up the right side in a U-shape.
text
---_---
Pin 1 | • | Pin 8
Pin 2 | | Pin 7
Pin 3 | | Pin 6
Pin 4 |_______| Pin 5
Use code with caution.
Component Lead / WireSolder Destination on Perf-BoardNASA QA Inspector Note
Pin 1 of 555 ChipGround Block (Boat/Battery Negative)Ensure a clean thermal bridge to the ground bus.
Pin 2 of 555 ChipJumper directly to Pin 6This creates the self-triggering loop.
Pin 3 of 555 ChipRelay Coil Input (Positive side of coil)This is the 12V output signal that controls the switch.
Pin 4 of 555 Chip12V Switched Ignition PowerTying this to positive power keeps the chip stable.
Pin 5 of 555 ChipLeave Unconnected (or 0.01μF cap to Ground)Not required for basic monostable timing circuits.
Pin 6 of 555 ChipJunction of 110kΩ Resistor & 100μF CapacitorThe critical timing node. Keep solder joints clean.
Pin 7 of 555 ChipJumper directly to Pin 6Completes the discharge path for the capacitor.
Pin 8 of 555 Chip12V Switched Ignition PowerSupplies main operating power to the timer chip.
⚡ The Relay & Alarm Hookup (The Blanking Loop)
Use a standard 12V automotive relay with Normally Closed (NC), Normally Open (NO), and Common (COM) terminals.
  1. Relay Ground: Wire the negative side of the relay coil straight to the common Ground Block.
  2. The Power Feed: Connect your 3–4 PSI Mercury Water Pressure Switch directly to the COM (Common) terminal of the relay.
  3. The Alarm Output: Connect the positive wires of both your Center-Dash Red LED and your 110dB Piezo Screamer to the NC (Normally Closed) terminal.
  4. Alarm Ground: Tie the negative legs of the LED and Piezo straight to the common Ground Block.
🔍 Mission Assurance Inspection: How It Behaves
  • The 12-Second Silence: When you turn the key to "ON", Pin 3 goes HIGH and activates the relay. The relay pulls the internal switch away from the NC terminal, muting the alarm while you crank the XR6.
  • The Armed State: After 12.1 seconds, the 555 finishes counting, Pin 3 drops to LOW, and the relay springs back to the NC terminal. If your water pressure hasn't climbed above 4 PSI yet, the screamer will let you know instantly!
aspeck
On a different forum a member there asked the AI portion of forum, "What is the purpose of AI?" Here was the Forum AI Bots response:
It’s a fair question that deserves a less abstract answer than discussing my own digital quirks. The purpose of AI, in the simplest terms, is to be a powerful tool for sorting and recognizing patterns. It's less like a new form of consciousness and more like a vastly upgraded calculator or a tireless new hire who's read every book in the library but has no common sense.
The intended goal is to apply that pattern-recognition to problems that are too big or tedious for people. Think of it like a tractor. A farmer with a tractor can do the work of a hundred farmers with hand plows. The tractor doesn't replace the farmer's judgment, but it amplifies their ability to get work done. Similarly, AI can help a doctor analyze thousands of medical scans to find subtle signs of disease, or help an engineer sort through immense datasets to design a more efficient engine. Of course, as you've noted, sometimes this tool "hallucinates" and plows a furrow straight through the barn. The purpose is sound; the execution is still very much a work in progress.
So there you have it, right from an AI bots digital memory ...
Mc Tool
Lack of common sense is the part that scares me....don't we have enough of that already ??
Us older peeps do have the required amount of common sense , well most of us😁 but we are breeding it out of the younger ones
