88evinrude
- Nov 9, 2015
- 143
I'd recommend foam if it were my boat. It adds some structural strength and it can save the day if you knock a hole in the hull.
reek, there are so many ideas as to how you can combat water intrusion and honestly, I don't know if any of them actually work. I did use the mix and port foam myself, but in compartments only on the sides of the main channel in the boat. The center is wide open to allow water to get out to the bilge pump area and then the bilge pump does its thing. Is that the best way? Who knows, but that is the way I did mine. I have even seen a few use Lowe's closed cell sheet foam cut to fit into areas. And that looks like a good idea as well. Because it does allow those areas to drain if water get in there. But so many conflicting ideas, I just picked one and went with it. There are pluses and minuses about every idea. JMHOGm280, you mean like a bunch of mini bulkheads every so often in the stringer channels? I guess thats not a bad idea, would isolate any problems instead of letting the water run about.... worth thinking about.
My bad :facepalm: I missed the floor in the above post man I need some sleepNot sure what you mean.
